Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Loose Drain Pipe Below Kitchen Sink :(
Thread Tools Display Modes
Old 02-16-2011, 01:00 AM   #1
DukeStratosphere
Rambling Gambler
Default Loose Drain Pipe Below Kitchen Sink :(
This really bums me out, man. One of the drain pipes below my kitchen sink is totally loose. Here's a picture of the whole apparatus, with the obviously bad connection circled in red...
And here's a closeup...
Apparently the whole apparatus, including the garbage disposal, has shifted its position enough over the years to make the pipe too short to fit its connections. Can I just go to some hardware store and get a slightly longer pipe?
I've never attempted a project like this before but I'm too poor to just call a plumber at the drop of every little hat that comes along, so any advice y'all may have to offer would be greatly appreciated.
Thanks in advance for your tips.
DukeStratosphere is offline
Old 02-16-2011, 02:31 AM   #2
Chris
Administrator
Chris's Avatar
Liked 931 Times on 786 Posts
Likes Given: 67
Yes you can. Pull that one out by loosening the black plastic srew where it is leaking and also the two small bolts on the disposer. Take it with you to the hardware store and get one a bit longer, you may have to get one a few inches longer and cut it down. This is a very easy task and I don't think you will have any problems with it.
Chris is offline
Old 02-16-2011, 11:27 PM   #3
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
Also, check to make sure that the basket strainer (that's the part that actually clamps down onto the sink, just above and out of sight on the right side in both of your pictures) is still tightened down onto the sink. Grab the bottom of it and see if you can push or pull it around. And then do the same to the disposal. If either of those have come loose, that is the real problem, and the loose drain pipe is just the symptom.
phishfood is offline
Old 02-17-2011, 02:03 AM   #4
PrecisionPlumbing
Master Plumber
PrecisionPlumbing's Avatar
Just buy a 1-1/2" slip joint extension and cut it to fit.
PrecisionPlumbing is offline
Old 02-17-2011, 03:54 AM   #5
SlowDrip
Plumbing Sales
SlowDrip's Avatar
Liked 1 Times on 1 Posts
Quote:
This, really.
Also, this is where I point out how much i absolutely detest those little pre-packed kits that require slip joints to function. Every time someone buys one from me I die a little.
SlowDrip is offline
Old 02-17-2011, 07:10 AM   #6
PrecisionPlumbing
Master Plumber
It would be the most simple repair for a homeowner
www.Precision-Plumbing.com
‎(469)-248-2136 Precision Plumbing providing Service Repair Remodels Installing Quality Products With a Best Rate, Best Warranty Guarantee! Serving the Dallas,Texas DFW MetroPlex for Over 10 Years! Clean job sites, Quality work. Service You Can Trust! M-39887
Kitchen sink drain Vad Toilets and Sinks 9 03-01-2012 05:59 AM
Toilet PVC drain pipe came loose from pipe that leads to sewer. tireshark General Plumbing Help 6 08-02-2011 01:20 AM
Kitchen sink pipe in wall dolfans General Plumbing Help 1 06-11-2011 02:04 PM
Loose Water Supply Pipe - should I worry? jebber45 Toilets and Sinks 12 05-13-2011 01:38 AM
Kitchen sink drain Jaredd2091 Toilets and Sinks 2 02-03-2011 02:48 AM
Newest Threads
