Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > cleaning perimeter drain with pressure washer
Thread Tools Display Modes
Old 01-11-2010, 02:36 PM   #1
Zeppelin
Default cleaning perimeter drain with pressure washer
My local rental company suggested I use their 3000 psi pressure washer to clean out my ceramic perimeter drains. They thought an auger would be too hard on the interior of these forty year old drains but that the pressure washer would do the trick and might even cut off some of the roots that have grown into the drains over the years. The washer comes with a 25 foot hose that should pretty well reach right through the drain from one corner to the next on the side of the house. What do you think?
Zeppelin is offline
Old 01-11-2010, 07:21 PM   #2
Local16 Omaha
Your #2 is my #1
Don't know about the roots, but high pressure hose drain cleaners are the way to go as far I am concerned. I have seen them make pipes look brand new inside.
Local16 Omaha is offline
Old 01-12-2010, 10:39 AM   #3
Dennis/Ohio
Zeppelin,
I'm assuming Jetter not pressure washer. A jetter will cut roots. Me being an old guy I can do most anything with cable also. Spinning cable with running water is what we had before jetters. Jetter is a pressure washer with a self-propelling nozzle. Multiple rear spray holes & usually one hole forward. The hose is usually more flexible and easier to be pulled through the pipe by water pressure.
Dennis.......
Restored 1961 Case 530 Hoe.
http://www.flickr.com/photos/big-hoo...20025494/show/
Last edited by Dennis/Ohio; 01-12-2010 at 10:44 AM. Reason: Got more space editing a Quick reply
Dennis/Ohio is offline
Old 01-12-2010, 01:52 PM   #4
Zeppelin
Default Pressure washer/jetter
Dennis,
When he showed the nozzle to me the spray holes were pointing backward at about a forty-five degree angle. I don't think there were any forward pointing spray holes. He mentioned in passing that it might cut some of the roots given the strength of the water spray. No guarantee on that.
The hose is fifty feet long, by the way, not twenty-five, so it is certainly sufficient for my house dimensions. I am just waiting for a mild, cloudy day without rain.
Bob
Quote:
Originally Posted by Dennis/Ohio View Post
Zeppelin,
Dennis.......
Case Backhoe 530
Zeppelin is offline
Old 02-16-2010, 02:45 PM   #5
Mr_David
Easily Amused
Mr_David's Avatar
Liked 895 Times on 726 Posts
Likes Given: 592
Quote:
Originally Posted by Zeppelin View Post
Dennis,
Bob
Not all Jetter heads have a foward spray. The foward spray helps clear the way so the rear spray can propell the hose and head foward.
a.k.a. Krazedav
Mr_David is offline
Old 02-18-2010, 01:26 PM   #6
Zeppelin
Default progress
Well, I finally dug out all of the perimeter drains along the side of the house, about 27 feet of them in all. They are the old concrete two foot lengths of pipe laid side by side around the house. One corner had been stove in by the installation of a fence post on top of it. Thus, this corner [not the corner where the seepage entered the crawl space, by the way] was completely plugged with earth and roots. The others did not have any roots inside them as it turned out.
I am still planning to clean the front and back drains [all concrete] using the Jetter. First I want to get the new plastic drain tiles in place, however.
Thank you for your advice and input. Much appreciated.
Bob
Zeppelin is offline
Old 04-28-2010, 09:19 PM   #7
devdally
Default Roots?
Haven't seen roots or any of the sort being washed off by a pressure washer. Now that got me thinking.
devdally is offline
Old 05-15-2010, 12:01 AM   #8
PeterTeamer
We deal with this situation all day long. We own a state-of-the-art jetter and it works wonders on drains we service. Customers are always skeptical of using the jetter instead of cabling because it costs a good bit more. We made this video to show the difference to anyone who was questioning the effectiveness. Click on The Tampa Bay Virtual Plumber and search for drain jetting in the box to find the first entry.
PeterTeamer is offline
Old 01-25-2011, 03:08 PM   #9
jancancook
_____________________
gold charms
Deutsch Franzoesisch Uebersetzung
jancancook is offline
Tags
perimeter drain
Making a Jetter by using a pressure washer? Dollar_Bill Drain and Sewer Cleaning 14 08-20-2017 01:45 PM
Adding a washer drain to main drain stack.... phantomvs General Plumbing Help 10 07-22-2012 12:18 AM
drain cleaning saladcafe Drain and Sewer Cleaning 6 08-03-2011 01:26 PM
How to add Utility Sink and Washer Drain to existing drain stack obriendigital General Plumbing Help 1 03-27-2011 02:15 AM
perimeter drain gradient Zeppelin Drain and Sewer Cleaning 6 01-25-2010 04:24 AM
Newest Threads
