My water tank is 1990. It looks good but we take vacations and I worry about it failing and the pump filling the basement... Her sister comes to look after the cats so we cant turn the water off when we are away (toilets)..
Is there a type of programmable pressure switch that will cut the pump off at say 20psi, but can then be manually over-ridden to get the pressure up past that ...ie to normal 60 psi ?
