Javedisian
I have a ongoing issue with my water pressure. I have a well. When we do something that uses a lot of water (like using the washer) we lose water pressure to the whole house. If I run the spicket outside we will get some pressure back but then it will go away at times. We had full pressure back at one point but when we did some wash it went back down. What's confusing is the spicket has full pressure and so does the hose hook ups on the house.
We checked the water pressure tank by letting some air out and seeing if any water came out and none came out. The pressure gauge says we are getting 40 psi
Any ideas?
Thank you for reading!
Any ideas?
