Gouda
My problem is similar to others I have been reading about here, but not exactly, so hopefully I can get some good advice.
I have a shallow well jet pump, a Gould with a attached pressure tank. Came as one assembly. It was installed five years ago and has been fine until now. Static pressure is a bit above 40 psi, when I use water I get good pressure for a few minutes then it starts dropping off. Water still flows but the volume and pressure fall off until the flow is very much reduced and pressure is near zero. The pump is still pumping and will stay on as long as I am calling for water. When I shut off demand, the pressure builds back up to 40ish and shuts off. I cannot see any leaks anywhere. Pressure stays up as long as I leave all the faucets closed. Hot and cold are the same.
Ideas and suggestions ?
