After removing the pvc coupling from the old drain pipe, the underside disintegrated. I was going to try and blow torch it to see if I can remove the pipe and replace it. Not much room to work with so close to the wall. Any suggestions as to whether you think this would work is appreciated. Pipe is 1 1/4" soldered into the larger pipe. Thanks!
