Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Tub shower problems
Thread Tools Display Modes
Old 01-18-2011, 02:09 AM   #1
eergie
Default Tub shower problems
My question is i have single knob "temptrol" faucets in my mid 80's built home, I recently replaced my water heater and notice the tub baths valves are not working correctly. The one in the walk in shower has been operating correctly but now we are remodeling our shower so we are going to use the tub bath, as i turn on the water and turn it all the way to the hot side it starts to lose water pressure on the hot side. I notice the tub bath on the other side of the house is doing the same thing, but the hot water works on the sinks and walk in shower fine. Did I do something wrong when i replace the water heater? Or did both cartridges take dump at the same time? It barely has enough hot water to take a shower or to activate the shower.
Your input would be greatly appreciated.
Thanks,
eergie is offline
Old 01-18-2011, 04:47 PM   #2
yny
yny's Avatar
Did you hook up the hot side to the hot side or did you put the cold on the hot side?
If you hooked it up wrong way that would be an issue.
Take pictures and post it. Visuals can only help the pros on here understand what's going on..
Section 608 Universal , Section 609, R 410 A cert , PM cert , IAQ cert , Green Cert
yny is offline
Old 01-18-2011, 07:01 PM   #3
havasu
havasu's Avatar
Liked 502 Times on 417 Posts
Likes Given: 72
Whenever you disrupt your plumbing, there is a strong likelihood you have loosened sediment which have collected in your valves. You might try dismantling your valves to see if it is full of crud.
havasu is offline
Old 01-19-2011, 06:13 PM   #4
eergie
Quote:
bingo, i just found some plastic peaces in my cartride.
eergie is offline
Old 01-19-2011, 06:43 PM   #5
havasu
havasu's Avatar
Likes Given: 72
So all is well now?
havasu is offline
Old 01-20-2011, 03:31 AM   #6
eergie
So all is well now?
I disassemble the cartridge and found a little plastic peace that looked like the size of a half of a dime. it's funny now i turn the shower on and there's plenty of pressure and 5 seconds later you here a clunk and then there's no pressure. I guess there's another peace in there some where. Any suggestions into how to get this other peace out?
eergie is offline
Old 01-20-2011, 11:12 PM   #7
phishfood
Liked 479 Times on 391 Posts
Likes Given: 640
Pull it all back apart, and flush it with the cartridge removed. Maybe you can get the pieces to blow out that way.
phishfood is offline
Old 01-21-2011, 03:22 AM   #8
Mr_David
Easily Amused
Mr_David's Avatar
Liked 31 Times on 23 Posts
Likes Given: 4
If it doesn't work you may have to back flush it.
One method is to disconnect the hot supply at the water heater.
Adapt a hose to it and send the water some place safe so it doesn't make a mess.
Cap off the tub spout and the shower head.
Make sure the the cold supply to the water heater is off and / or cap the open hot outlet on the water heater.
With the tub valve reassembled, open it to mix the hot and cold equally. since the hot is disconnected the cold will flush back into the hot and dump out the water heater supply.
That is, if the tub valve does not have a pressure balance mechanisim that will not allow the water to cross through.
Mr_David is offline
Problems with venting??? christaylor General Plumbing Help 4 04-11-2012 05:52 PM
Shower, new house... problems! down2earthlv Showers and Tubs 2 01-31-2012 12:46 AM
Shower Pressure and Temp. Problems Mantis General Plumbing Help 63 02-16-2011 12:04 AM
Re-plumb - now problems ramilin General Plumbing Help 3 07-28-2010 03:09 AM
Question: custom shower pan (problems) nuklep General Plumbing Help 10 03-22-2010 07:08 AM
