Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Kitchen sink: hot water faucet not working
Thread Tools Display Modes
Old 01-17-2011, 10:55 PM   #1
kmillican
Default Kitchen sink: hot water faucet not working
Hi, my girlfriend is having trouble with getting the hot water side of her kitchen sink to work. I took a look to make sure the valve under the sink was turned on, which it was on very little. I had to cut a wood shelf under the valve to finish turning the valve all the way on. Even with doing so, with the hot water faucet turned all the way on, it will only dribble, or barely come out of the faucet. The sink is a double sink with a knob for hot water and a separate knob for cold water. The cold water side works fine, and the hot water works fine throughout the rest of the house. Any recommendations would be greatly appreciated.
kmillican is offline
Old 01-18-2011, 01:42 PM   #2
DFBonnett
Liked 17 Times on 14 Posts
Likes Given: 22
I'd start by disassembling the valve and checking the washer.
DFBonnett is offline
Old 01-18-2011, 08:45 PM   #3
kmillican
I will do that, thank you very much.
Kitchen faucet/sink noises. andy31 General Plumbing Help 11 10-11-2012 09:19 PM
Need easiest way to run hot water from kitchen sink area Swamibob General Plumbing Help 0 01-27-2012 08:11 PM
One Side of Faucet Not Working mrsmnc Toilets and Sinks 1 10-23-2011 11:13 PM
Low Pressure - Hot Water in Kitchen Faucet Only mbgray General Plumbing Help 5 06-05-2011 06:12 PM
Kitchen Sink - Cold, no water comes out, hot is fine nnhubbard General Plumbing Help 0 04-18-2011 03:18 PM
Newest Threads
