Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > How fix a loose Toilet tank handle
Thread Tools Display Modes
Old 01-10-2011, 02:27 AM   #1
Mr_David
Easily Amused
Mr_David's Avatar
Liked 869 Times on 706 Posts
Likes Given: 577
Default How fix a loose Toilet tank handle
Well I had to replace my toilet tank handle so I thought I'd share a little tip that can be helpful.
Often the hole in the tank is larger than the square sides of the handle that are supposed to keep the handle in place.
So I made a video.
a.k.a. Krazedav
Mr_David is offline
Old 01-10-2011, 02:34 AM   #2
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
For those of us who are "internet challenged" (read dial-up) can you detail the process in text?
phishfood is offline
Old 01-10-2011, 02:44 AM   #3
Mr_David
Easily Amused
Mr_David's Avatar
Likes Given: 577
I'm literary challenged and the video is my best shot at sharing this tip.
a.k.a. Krazedav
Mr_David is offline
Old 01-10-2011, 02:47 AM   #4
havasu
Administrator
havasu's Avatar
Liked 1114 Times on 906 Posts
Likes Given: 336
Nice video Dave!
Phish, Dave's video shows how many times, the square in the porcelain tank is manufacturered a bit too large, so when you insert the toilet tank handle, it will rattle about an eighth of an inch in all directions. He uses plastic copper pipe hold downs/supports, which are about the same thickness as the eighth inch gap in the porcelain. By cutting the wings off the supports, he inserts them into the gap between the handle and the porcelain. Once the handle is tightened, there is no more rattling from the loose fitting handle.
havasu is offline
Old 01-10-2011, 02:57 AM   #5
phishfood
Administrator
Likes Given: 1739
Ahhh, the old oversized flush handle hole!
I always keep several CTS flat straps and suspension clamps in a bucket in my truck. Next time I run into problems with a loose flush handle, I will give this a try.
Toilet PVC drain pipe came loose from pipe that leads to sewer. tireshark General Plumbing Help 6 08-02-2011 01:20 AM
Loose Drain Pipe Below Kitchen Sink :( DukeStratosphere General Plumbing Help 5 02-17-2011 07:10 AM
Tub spigot and handle loose Wildduk Showers and Tubs 2 01-21-2011 12:21 AM
Toilet Tank Leak - Cracked Tank? RobZ General Plumbing Help 5 11-09-2010 11:50 PM
Toilet tank will not fill. cnl390 Toilets and Sinks 2 08-01-2010 03:12 PM
Newest Threads
