Hi
Signed up again......the account never recognized my old user name. Great to see the site is still running strong. My hello's to speedbump!
I have a sand point well......made in 2012. Good water and good quantity as well to this day. Johnson point.......8 slot........36" screen down approximately 22 feet from surface. Used as a recreational property.
Problem is I am getting some sand.....not much but noticeable in toilet tank bottom and when I drain the hot water tank at the end of the season. (late October). I am not getting much but you can see especially when the hot water tank spurts out its last gallon or two. Does this support us getting a in line water filter or perhaps one on the drinking fawcett only. I spoke to Johnson and they said going to a 6 slot won't make much of a difference and to expect some sand with a sand point well.
I realize as well that in line filter can be a PITA therefore . If I were to install one do I install it after the pump but before the tank?? or after the tank but before hot water tank?? I have attached two pictures. Thank you. Happy new year from Canada.
