Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > New Water Heater, Dishwasher Going Crazy
Thread Tools Display Modes
Old 01-01-2011, 11:33 PM   #1
abacab
Default New Water Heater, Dishwasher Going Crazy
Last month I installed a 50 gallon water heater. Water was previously heated off the furnace so I rerouted the plumbing and everything worked fine. No leaks and hot water out of all necessary appliances. The only problem is when the dishwasher is running, certain cycles with cause the pipes to vibrate so much that it shakes the whole house. I tied the pipes down more but no change. There were no issues with the dishwasher before the switch and no other appliances appliances or fixtures had the problem, except for when I initally purged the air from the lines after installation. Any idea what the problem and fix is?
abacab is offline
Old 01-02-2011, 01:04 PM   #2
phishfood
Liked 477 Times on 389 Posts
Likes Given: 639
That sounds odd.
Is there a shock arrestor installed on the supply piping near the dishwasher? If not, you might try adding one in. But I don't quite know why it would only start doing after you installed the water heater, and not before.
phishfood is offline
Old 02-17-2011, 01:16 AM   #3
PrecisionPlumbing
Master Plumber
PrecisionPlumbing's Avatar
Install a Water hammer arrestor near the dishwasher
www.Precision-Plumbing.com
‎(469)-248-2136 Precision Plumbing providing Service Repair Remodels Installing Quality Products With a Best Rate, Best Warranty Guarantee! Serving the Dallas,Texas DFW MetroPlex for Over 10 Years! Clean job sites, Quality work. Service You Can Trust! M-39887
PrecisionPlumbing is offline
Help. Removing Dishwasher PEX gti303 General Plumbing Help 2 05-02-2012 11:03 PM
Dishwasher Drainage Question Dantana General Plumbing Help 1 03-04-2011 08:28 PM
Dishwasher came lose CPTTango30 General Plumbing Help 3 06-10-2010 04:21 AM
Crazy bad toilet fill valve Handyguys Project Display 5 04-06-2010 02:45 PM
Standing Water in My Dishwasher? JeeperCreeper General Plumbing Help 4 01-16-2010 04:25 AM
