Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Tools and Equipment > Cutting Plastic Pipe
Thread Tools Display Modes
Old 01-08-2010, 03:14 PM   #1
blitz
Default Cutting Plastic Pipe
Anyone use the Ridgid or Reed quick release cutters with plastic cutting wheels for pvc or abs?
My co-worker has Reed's as they top out at 3" they are the TC4Q. If that's the case, should the TC6Q's be able to handle 6"?
blitz is offline
Old 01-08-2010, 03:31 PM   #2
majakdragon
I have not seen plastic pipe cutters with wheels. I use the ratchet type (Ridgid) but only for 2" and below. Since i don't use the larger pipe much, I have a handsaw for cutting. Going by the numbers, I would agree that the one you mentioned would cut 6" pipe.
If you have never made a mistake, you probably haven't done much.
majakdragon is offline
Old 01-16-2010, 08:24 PM   #3
S7s
S7s's Avatar
My TC3 cuts 3" just fine. I think you've got something out of whack.
S7s is offline
Old 01-19-2010, 10:46 PM   #4
Reedwalker
Expert Turd Herder
Reedwalker's Avatar
Liked 1 Times on 1 Posts
I use a reciprocating saw. With a bit of practice you can make very straight cuts fast.
Reedwalker is offline
Old 01-30-2010, 02:01 AM   #5
clydewater
I use an abrasive chop saw for pipe over 2".
Provides quick clean cut that is square
Thanks
Richard
clydewater is offline
Old 07-24-2010, 04:28 PM   #6
redmanplumber
i use a combo of cutters, chop saw for rough ins and top outs. recip saw for small jobs, ratchet cutter for small pipe and a rigid cutter with pvc blade for finish work( less mess to clean up and more precise) never use hack saw though thats for non plumbers lol
redmanplumber is offline
Old 10-14-2010, 06:27 PM   #7
clydewater
anyone try the Milwaukee M12 PVC Cutter and if so what have you thought of it? I have one but the jury is still out on how well it works
On short pieces it will explode the pipe.
Longer pieces it works OK but takes practice to get a good square cut
Old 10-15-2010, 02:02 AM   #8
phishfood
Liked 508 Times on 409 Posts
Likes Given: 674
I have been wanting to try one of those out. But when I look at the price tag, my mongo ratchet cutters, cordless Sawzall, and yes, even my unprofessional hacksaw win out.
phishfood is offline
Old 10-18-2010, 03:02 PM   #9
speedbump
Water well and pump tech
speedbump's Avatar
Liked 56 Times on 53 Posts
Likes Given: 14
I too use the unprofessional hacksaw. Straight cuts are no problem and the blades are cheaper and last much longer.
I've tried all the others and they just don't last and a few cuts and they are getting dull.
speedbump is offline
Old 01-06-2011, 05:46 PM   #10
Plbgbear
don't worry phish, my unprofessional hacksaw does just fine for me also.
Plbgbear is offline
Tags
pipe, plastic
Cutting and Soldering pipes help Kshelley41 General Plumbing Help 10 11-24-2011 02:36 AM
cutting a flexible coupling bob_d General Plumbing Help 1 11-18-2011 12:20 PM
cutting vent pipe mijoda52 Showers and Tubs 3 10-09-2011 09:05 PM
Cutting out wall studs PipePig101 General Discussion 1 03-02-2010 04:59 PM
Newest Threads
