Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > New tub drain won't tighten enough. HELP!
Thread Tools Display Modes
Old 08-27-2014, 03:14 PM   #11
DIYMike99
Liked 3 Times on 3 Posts
Likes Given: 1
Quote:
Originally Posted by Zanne View Post
Ok, dumb question: what does it mean when you say it was cross-threaded? And what is the tub shoe?
(I'll need to know this for some future projects to avoid problems)
Also is there going to be more wood put under that tub where you can see the bottom of it?
I know its cosmetic, but for some reason I worry about the support. It looks like there are feet to support it that are just hanging in the air above the P-trap. I'm not sure if that is an issue or not though.
There are other feet. That tub has been in that position for 15-20 years or so.
DIYMike99 is offline
Zanne Likes This
Old 08-27-2014, 11:40 PM   #12
Zanne
Zanne's Avatar
Liked 154 Times on 136 Posts
Likes Given: 2704
Quote:
Originally Posted by journeyman View Post
cross threading is when you dont thread a fitting properly and it gets threaded in at an angle. it happens alot with tubs because you are threading metal into plastic. john is referring to the strainer and shoe that mount to the bottom of the tub. once you cross thread the only thing you can do is start over.
Ohhh! Ok. Thank you. I will have to be careful of that if/when I install a new tub. If I'm understanding it correctly, I sometimes crossthread lids to my drinks (as well as jam jars) when I'm trying to put them back on. I somehow get them at an angle. I really need to find some exercises to do to improve my coordination and hand strength.
So, putting just the shoe on would make it easier to get it on straight-- since it will be a symmetrical shape, right? And then the pipes get hooked in...
Zanne is offline
Old 08-31-2014, 07:11 AM   #13
DIYMike99
Likes Given: 1
I just ended up redoing the whole thing and installed the shoe first as recommended. Seems to work alright. The only tricky part was was putting the To on the overflow and shoe extensions.
Thanks for the advice.
Zanne Likes This
Old 09-02-2014, 09:17 PM   #14
Zanne
Zanne's Avatar
Likes Given: 2704
Glad it worked out for you, Mike!
Zanne is offline
Vavle seat wont tighten net_jerko Showers and Tubs 1 10-19-2013 02:44 PM
At a loss...how to tighten faucet handle hnickm General Plumbing Help 8 02-28-2013 03:33 PM
Newest Threads
