Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Water Heater Exhaust
Thread Tools Display Modes
Old 08-25-2014, 09:39 PM   #1
CalifLove
Default Water Heater Exhaust
Hello all,
Hoping some of you may have expertise in this area. I purchased my home - new construction - nearly 7 years ago. The place came with a State Select 50g water heater with an exhaust blower unit connected to it at the top. That blower vented into black ABS out the top and then 90 degree on out to a whole for it on my garage wall.
This water heater officially died recently (leaking rusted water out of the bottom) - wholes in tank, not from valve or otherwise. I replaced it with a Rheem Performance Platinum unit from home depot. I went with the Performance Plat because of the $200 rebate from our utility company (PGE in NorCal) which made its costs in line with the standard performance line I started looking at.
Anyway, I haven't been able to find out a concrete answer on this - do I need a blower on the new heater since it vents essentially up and to the right? Also, since it is ABS, my understanding is the exhaust gases need to be cooled a bit and the blower provides that function as well mixing ambient air with the exhaust from the burner before expelling out the vent?
Any help is greatly appreciated - thank you!
CalifLove is offline
Old 08-26-2014, 01:41 PM   #2
IFIXH20
HERE TO HELP
Liked 229 Times on 180 Posts
Likes Given: 163
Califlove, You went from a power vent water heater to a natural draft water heater. Your water heater calls for type B vent (double wall sheet metal piping). You need to have a PROFESSIONAL come out ASAP to re-run your flue properly or replace the water heater with a power vent water heater so the exsisting flue can be used. Flue gases should not be cooled quickly be caused the unit will not draw porperly and the gases produces carbon dioxide (C02) which is very acidity. Hope you have carbon monoxide detectors.
IFIXH20 is offline
People Like This
Old 08-26-2014, 04:44 PM   #3
SHR
Liked 117 Times on 88 Posts
Likes Given: 230
I hope this post is a troll. The water heater installation you describe will/has put you and your family in extreme danger. You purchased and installed (?) an incorrect water heater for your replacement. Your home will burn down and you and your family may die if you use the water heater you describe. You obviously did not pull the required permits because no inspector would have allowed this installation.
SHR is offline
People Like This
Old 08-27-2014, 03:32 AM   #4
journeyman
the professional
journeyman's Avatar
Liked 87 Times on 68 Posts
Likes Given: 87
shr i cant believe this post. i am glad you explained bluntly the potential danger they are putting themselves in. get that heater out of your house if you dont know what you are doing then dont do it. there is a reason why plumbers get paid what they get paid. by trying to save money you could be killing your family. all heater installs need to be inspected and installed by a professional
journeyman is offline
Old 08-28-2014, 04:19 PM   #5
Matt30
Liked 160 Times on 132 Posts
Likes Given: 27
He hasent replied yet. Hopefully its not too late!
Matt30 is online now
SHR Likes This
Gas heater exhaust roar - some worse than others? packardv8 Water Heaters and Softeners 0 06-08-2014 11:47 PM
Water heater feed pipe shot. and now i have to replace my whole heater. chucksrt Water Heaters and Softeners 1 05-20-2013 02:14 AM
Bathroom Exhaust Vents projectman General Plumbing Help 0 04-06-2013 12:51 AM
rear exhaust toilet - changing wax gravine General Plumbing Help 8 01-25-2012 12:39 AM
Water in bathroom exhaust vent magikal General Plumbing Help 4 03-31-2010 04:12 PM
Newest Threads
LATEST SPONSOR DEALS
