Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Products > Fresh air vent cover
Thread Tools Display Modes
Old 08-26-2014, 02:57 PM   #1
halfaplumber
Default Fresh air vent cover
I need to install a cover on my fresh air vent on the side of my house...does anyone know if anyone makes a cover, or an addaptor, that corrects for the ridges in vinyl siding? If I just install a flat cover over the vinyl siding it does not sit flush and the space around it caused by the siding would require excessive caulking. Any info would be appreciated.
halfaplumber is offline
Old 08-27-2014, 02:19 AM   #2
havasu
Administrator
havasu's Avatar
Liked 546 Times on 450 Posts
Likes Given: 94
I've never seen one but it is certainly needed. Maybe call a vinyl siding company?
havasu is offline
Old 08-27-2014, 03:39 PM   #3
halfaplumber
Thanks.
I did some more research and finally found something. It's a surface mounting block which can be placed on the siding without having to rip out the siding. It gives you a flush surface to mount lights, vent covers, etc. on. The only other mounting blocks I knew of were the ones you had to put on before the siding...so i did not want to have to rip out the siding...here's the link for members' info/reference:
http://www.menards.com/main/doors-windows-millwork/mobile-manufactured-home-parts/exterior/vinyl-siding-vents/vinyl-surface-mounting-block/p-1379276.htm
Do you cover heating? Les1 General Plumbing Help 2 10-06-2013 05:13 PM
American Standard fresh air intake? DrWhatsHisName General Plumbing Help 1 05-22-2012 11:16 PM
How to remove the cover? danielsd Drain and Sewer Cleaning 3 09-24-2011 11:19 AM
Cover for water well Knucklehead Pumps and Wells 4 08-10-2011 01:08 PM
Fresh air vent fixit123 General Plumbing Help 1 08-21-2010 02:11 AM
