Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > What "nut" to match a 1/2" MIP?
Thread Tools Display Modes
Old 08-26-2014, 05:08 PM   #1
questy
Default What "nut" to match a 1/2" MIP?
Ok, this might be a dumb question, but I have a "Nylon Hose Barb" A-269
3/8"x 1/2" MIP (The outside of the threading looks like 7/8" ).
I want to put a low profile, preferably plastic, nylon or pvc type of Nut on the threads, to tighten it down against a surface, and being a newbie, don't know what size of nut to look for, or even where to find one. I was looking 1/2" but they look too small (online) and thinking I should be looking for a 7/8" part? So question 1, what size specification should I be looking for? I would consider a less-corrosive metal part as well, if that's the only option.
The application for this is a make-shift basin drain, thus the need for a low profile nut ( I may also cut the un-needed threads.) I also want to put a washer on the bottom of the nut to prevent leaks between it and the bottom of the basin.
Note, I'm willing to take another part like a coupler or cap and cut it to give me my part, if not readily available. So question #2, what part should I be looking for?
Any help is greatly appreciated, thanks!
questy is offline
Old 08-30-2014, 02:31 PM   #2
Caduceus
Caduceus's Avatar
Liked 223 Times on 159 Posts
Likes Given: 123
Look in the electrical section of a hardware store for a 1/2" lock nut. Take the fitting with you to make sure it's the right size. Also pick up a 1/2 in. Rigid Conduit Reducing Washer to act as a friction ring between the lock nut and the rubber washer.
Buy two of every thing and see if this works.
Thread on a lock nut, friction ring then washer, in that order.
Put fitting threads through hole of pan.
if you have enough room left on the threads in the pan, put on rubber washer, friction ring and lock nut in that order.
Now you can tighten the nuts from both sides of the hole to seal it.
If you don't have enough threads to do both sides then just the inside of the pan should work and some 100% clear silicone sealant for insurance.
Caduceus is offline
People Like This
Old 08-31-2014, 01:40 AM   #3
phishfood
Liked 547 Times on 440 Posts
Likes Given: 733
^beat me to it!
Lake County, Florida plumber
Springtime Plumbing Services, LLC
License #11067533
352-433-1912
phishfood is offline
Water Supply Abruptly Stops - Local "Experts" Disagree as to Cause TOKA-WIL Pumps and Wells 1 05-27-2014 12:12 PM
Tub overflow seal "....not designed for constant exposure to water" ????? itbedave Showers and Tubs 9 04-22-2014 03:23 PM
Adjustable "Metric" and "SAE" wrenches? havasu Plumbing Tools and Equipment 3 04-12-2011 06:58 PM
Outside spigot with plastic "winterizing" piece causing leak thunderbry General Plumbing Help 2 06-19-2010 01:09 PM
Vice President Joe Biden or Jeff Dunhams "Walter" SilverBack4Jack General Discussion 5 01-30-2010 12:53 AM
