Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > ranch plumbing setup suggestions?
Thread Tools Display Modes
Old 05-21-2017, 03:09 PM   #11
Zanne
Zanne's Avatar
Liked 181 Times on 161 Posts
Likes Given: 3250
Does the pond have any water in it now?
And does it rain where you live?
If you lived near my area the pond would get filled fairly quickly by the rain, but I know some areas are dry.
I think it would be better to fill the pond up over time, as Frodo suggested.
If the pump is hooked to PVC and constantly runs it can melt the PVC and cause leaks. I've had this happen numerous times when my pump got hot (mostly bc of a problem with the tank not filling all the way bc the ancient float lever setup was not working properly anymore).
Also, since some of the water will be going to your house, have you considered some sort of water filtration/softener setup going to the house? Sometimes you can end up with sediment that will coat the pipes and all of the fixtures.
Zanne is offline
Will this DWV setup work? Techno101 General Plumbing Help 9 07-27-2016 02:46 AM
Pump setup recommendations Levi Pumps and Wells 11 05-07-2016 09:22 PM
Has anyone ever seen a plumbing setup like this? tom5170 General Plumbing Help 3 02-27-2015 01:51 PM
PEX Homerun System Setup?? mcintoshmc General Plumbing Help 13 12-01-2012 09:38 PM
Newest Threads
