Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Toilet Leak - tank-to-bowl bolt
Thread Tools Display Modes
Old 01-09-2017, 11:59 PM   #1
HiHeyThereHello
Established Member
Default Toilet Leak - tank-to-bowl bolt
Hello all.
I am at a loss of what to do with this one. I recently purchased a house built in the 1950s. In the second bath, there's a Sedona toilet that has been leaking. Upon further inspection, I found it's a tank-to-bowl rubber washer that wasn't sealing all the way. The toilet was also running periodically, so I bought a Fluidmaster repair kit and replaced everything, including the tank-to-bowl hardware. However, the leak persisted. It is only a leak from the left bolt, closest to the water supply line.
I've tried replacing all of the rubber washers a second time, and even bought thicker beveled rubber washers but to no avail. I do not see any hairline cracks/chips in the porcelain and scrubbed the area under the washers as best I could.
I don't really want to silicone under the washer, as that seems like a "cutting corners" method - it would be annoying to remove if it didn't fix the problem, too.
Any advice for me? Here's a picture
HiHeyThereHello is offline
Old 01-11-2017, 10:08 AM   #2
frodo
Just call me Macgyver
frodo's Avatar
Liked 1768 Times on 1507 Posts
Likes Given: 368
are your sure it is the tank bolts ?
could it be the big spud washer or nut
My advice is free, If I have helped you and you wish to help the site out with a gift
use this link
http://www.plumbingforums.com/forum/...faq=supporting
frodo is offline
SHEPLMBR Likes This
Old 01-11-2017, 05:26 PM   #3
tanksnotanks
Liked 18 Times on 16 Posts
Try double nuts
The first one with tank off tighten the bolt with the rubber washer
Then attach tank to bowel with second set of nuts
tanksnotanks is offline
Old 01-12-2017, 12:55 AM   #4
Mr_David
Easily Amused
Mr_David's Avatar
Liked 795 Times on 644 Posts
Likes Given: 543
Quote:
Originally Posted by tanksnotanks View Post
Try double nuts
I do that when there is room between the bowl and tank.
look for some nuts that are thinner if that is a problem.
I have seen others install the bolts with a metal washer between the bolt head and the neoprene washer before it is installed into the hole.
the neoprene washer has to seal against the under side of the bolt head and the tank. metal washer (brass or stainless steel) only goes on the exterior side of the tank and or bottom end of bolt.
a.k.a. Krazedav
Mr_David is offline
phishfood Likes This
Toilet tank to bowl leak. Which part is leaking? Goalie35 Toilets and Sinks 1 12-30-2015 05:26 PM
Need tank-to-bowl gasket for 1954 Case ? Toilet IWIDESHUT Toilets and Sinks 2 11-06-2013 12:49 AM
Tank to bowl leak with 10 yr old Sterling toilet jccva Toilets and Sinks 10 01-01-2012 12:33 AM
4 bolt bowl to tank and square type gasket? merlin12volt Toilets and Sinks 4 01-07-2011 03:32 PM
Toilet Tank Leak - Cracked Tank? RobZ General Plumbing Help 5 11-09-2010 11:50 PM
Newest Threads
