Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > thermostatic valve isolation valves
Thread Tools Display Modes
Old 10-12-2017, 02:59 PM   #1
drfeno
Liked 1 Times on 1 Posts
Likes Given: 5
Default thermostatic valve isolation valves
I will be installing a 2 outlet thermostatic shower mixing valve in a new bathroom I'm putting in. I've read that by code, the valve must have isolation valves on the hot and cold supplies. My question is first, it this true, and if so, do the shut off valves need to be "dedicated" to the thermostatic valve. I have valves on the hot and cold supplies that can isolate the entire new bathroom. Do these count for the thermostatic valve, or do I need separate ones that can isolate the valve specifically?
drfeno is offline
Old 10-13-2017, 02:37 AM   #2
Mr_David
Easily Amused
Mr_David's Avatar
Liked 837 Times on 678 Posts
Likes Given: 554
Which code are you using? Stop valves are required for multi unit mixing valves. This is so you can make repairs with out effecting other units.
If you are in a single family dwelling then I am pretty sure integral stops are not required
a.k.a. Krazedav
Mr_David is offline
Thermostatic valve and town inspectors wang888 Plumbing Building Code 2 09-19-2017 05:43 PM
Thermostatic Valve Related Query rajfunk General Plumbing Help 3 11-02-2014 12:33 PM
Best brands of thermostatic valves Angelique General Plumbing Help 2 04-02-2014 02:31 AM
Help finding a Proportional Mix valve (not thermostatic)? bcomstock15 General Plumbing Help 0 03-13-2014 11:02 PM
Thermostatic Valve dripping after use SerenityNow Showers and Tubs 1 02-24-2011 04:41 AM
Newest Threads
