Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Hot Water Recirc Pump Blues
Thread Tools Display Modes
Old 10-11-2017, 06:51 PM   #1
WuXiaoBai
Likes Given: 1
Default Hot Water Recirc Pump Blues
I came on about a year ago with a similar but different issue. We did identify that the shower leak was due to the recirc valve dealing with uneven hot/cold levels with toilet flushes/dishwasher/washing machine use. We like having hot water instantly enough that we've put up with it, and a plumber who came out said with our builder it's a known issue and either you deal with it or you unplug the pump and just wait.
We've been using it since then, but recently we had a power outage that knocked it out of whack. Once the power came on, it started making a shuddering sound again, so I did what had worked previously: I unplugged the recirc pump and re-plugged it about a minute later. Since then, we've not had instant hot water, and I can't seem to find info on how to fix it on all the DIY blogs/sites I've been searching.
Any help to get my hot water recirc pump back going is greatly appreciated!
WuXiaoBai is offline
Old 10-12-2017, 02:01 AM   #2
havasu
Administrator
havasu's Avatar
Liked 1088 Times on 882 Posts
Likes Given: 313
What brand of pump? If you have confirmed power, and confirmed that the timer is not stopping the pump from running, you will need to replace the pump.
havasu is offline
SHR Likes This
Old 10-12-2017, 08:32 AM   #3
frodo
Just call me Macgyver
frodo's Avatar
Liked 1819 Times on 1551 Posts
Likes Given: 379
a little more info on your home.please
you said that the problem is known to the builder?
if you are still under warranty, demand the problem be fixed
My advice is free, If I have helped you and you wish to help the site out with a gift
use this link
http://www.plumbingforums.com/forum/...faq=supporting
frodo is offline
Hot water recirc pump-which is best Jimongee General Plumbing Help 0 12-08-2016 02:46 AM
Hot water recirc pump install Jimongee General Plumbing Help 1 05-19-2016 02:54 AM
Hot Water Recirc Pump with Water Softener? ewood Water Heaters and Softeners 0 10-22-2014 05:37 AM
Question on Hot Water Heater Recirc. Pump beantech Water Heaters and Softeners 2 08-13-2011 02:28 PM
Hot water recirc pump installed, now hot water in cold lines? hevykevy420 General Plumbing Help 0 09-09-2010 03:35 PM
Newest Threads
