Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Mysterious Toilet Draining Issues
Thread Tools Display Modes
Old 09-24-2017, 04:13 PM   #1
mferrigno
Default Mysterious Toilet Draining Issues
Hello. I have a toilet that is very mercurial in a house I recently purchased.
Some flushes (10%) it works exactly as designed, some the water swirls around the bowl and never really drains fully but definitely doesn't back up either (80%), and some the water drains slowly and nearly fully empties the bowl (10%).
I've examined the tank and mechanically everything appears to be working properly. There was *a lot of black sediment* and some rust build up that I've nearly completely removed.
I've also used a 6' snake to clear any blockage. It did not help at all.
Finally, assuming it was a blockage, perhaps further than my 6' snake could reach, I filled a 5 gallon bucket of water and poured the whole thing down the toilet--it drained perfectly. This says to me there is no blockage issue.
So what's the likely problem? I'm stumped.
mferrigno is offline
Old 09-24-2017, 04:22 PM   #2
Mr_David
Easily Amused
Mr_David's Avatar
Liked 837 Times on 678 Posts
Likes Given: 554
Dump several buckets just to make sure.
I have had stoppages just beyond the reach of an auger and it takes 3 or more buckets or flushes to make it back up.
A slow drain will suck or siphon a bowl down as it slowly drains by the blockage.
maybe a picture will help. Show me yours and i'll show you mine
a.k.a. Krazedav
Mr_David is offline
Old 09-28-2017, 05:36 PM   #3
CT-18
Liked 29 Times on 25 Posts
Flip the tank lid over and look for a date stamp when it was made. It may be that the ports are getting plugged and not allowing the water to flow in properly. Take that bucket and dump it real slow and see what happens.
CT-18 is offline
Old 10-01-2017, 03:03 PM   #4
mferrigno
I uploaded a video to help. You can see the water swirls around the bowl, doesnt back up, and slowly drains partially.
https://youtu.be/FBmx8dSgFrs
The toilet was made in 1994 and neglected by the previous owner. We have well water and they rarely replaced the sediment filter, added salt to brine tank etc... so the tank of this toilet was filthy before i cleaned it with rust away.
Old 10-01-2017, 10:01 PM   #5
johnjh2o
johnjh2o's Avatar
Liked 712 Times on 541 Posts
Likes Given: 604
Try cleaning the holes under the rim.
John
johnjh2o is offline
Old 10-02-2017, 01:27 PM   #6
mferrigno
I've cleaned the toilet extensively. I don't believe that is the problem.
Old 10-02-2017, 04:48 PM   #7
CT-18
The holes on the underside of the rim need to be cleaned. I have done this with a pipe cleaner on more than one occasion. At 23 years old the toilet may be on the clock. The old saying "They don't make em like they used to" is true in some cases.
CT-18 is offline
Old 10-03-2017, 12:46 PM   #8
DFBonnett
Liked 17 Times on 14 Posts
Likes Given: 22
Had the same problem with an American Standard at my daughter's house. A small piece of plastic, slightly larger than a nickel, must have gotten down from the tank and was sometimes blocking the smallish hole at the front of the bowl at the bottom. Finally found the problem after noticing that when the flush was poor there was no jet of water coming from that hole. Managed to get my pinky in the hole and work the plastic out. Might be something to check out in addition to cleaning the holes under the rim.
FWIW
DFBonnett is offline
Old 10-05-2017, 04:33 AM   #9
penguin
Liked 1 Times on 1 Posts
I can see the buildup in the bottom of the toilet from the well water. Chances are the toilet is closing itself off with buildup. Urinals have the same issue. If you pull the toilet and look at the bottom of the toilet, you may see the buildup. You can try applying a descaler ( sizzle or clobber) to the toilet see if it flushes better.
penguin is offline
Slow / No Draining Toilet adolloff Toilets and Sinks 8 05-23-2016 01:08 AM
New toilet/plumbing having issues kittywings Toilets and Sinks 6 01-10-2014 11:16 PM
Tub draining/toilet bowl syndrome Septik Showers and Tubs 1 03-21-2012 09:28 PM
toilet not draining right marcplante Toilets and Sinks 8 05-19-2011 03:39 AM
Toilet draining daily? FiveDegrees General Plumbing Help 8 09-12-2010 05:40 AM
Newest Threads
