Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Building Code > Rough Inspection with slab
Thread Tools Display Modes
Old 09-18-2017, 05:08 PM   #1
kid
Likes Given: 1
Default Rough Inspection with slab
My house is built on a slab, and I am doing a complete renovation. I am going to build up the floors on a 2x4 deck to add some insulation, and run pex home runs.
My issue is going to be with my waste and vent pipes. My inspector wants to see all waste and vent lines before they are closed up (normal).
However, how do I put up the walls containing vent stacks and branches, when I can't complete the floor the wall goes on? It will be only one wall, and it is not structural. Can I "float" the wall on strips of plywood, then secure full decking after inspection?
kid is offline
Old 09-18-2017, 06:47 PM   #2
CT-18
Liked 29 Times on 25 Posts
You do it like we do underground piping. You just stub it up a foot or so, then continue after inspection with the walls.
CT-18 is offline
Old 09-18-2017, 07:41 PM   #3
frodo
Just call me Macgyver
frodo's Avatar
Liked 1819 Times on 1551 Posts
Likes Given: 379
3 separate plumbing inspections
underground
above ground
trim
I am wondering how you think a 2x4 joist will give you enough room to install the pipes with a 1/4'' per foot slope for drainage
My advice is free, If I have helped you and you wish to help the site out with a gift
use this link
http://www.plumbingforums.com/forum/...faq=supporting
frodo is offline
Old 09-18-2017, 07:59 PM   #4
kid
Likes Given: 1
Quote:
Okay, I was under the impression they would want to see all of the branch joints in the wall, while checking the waste pipes.
Quote:
underground
above ground
trim
My main is in the slab. I will be digging that out and replacing it. My slab has a drop off in it, so the 3 inch line that I will run to my main will be 5' long. This will be between 2x6 joists. I only need 1 1/4" to reach the main. Everything with waste runs on the wall, so I only need stubs, then straight down to main. Hope that makes sense.
kid is offline
new 40x40 slab on grade rough in bradbergemann Project Display 11 03-27-2017 11:54 PM
rough-in inspection for soaking tub shaken-n-stirred General Plumbing Help 2 03-25-2016 10:17 PM
Rough-in inspection shaken-n-stirred General Plumbing Help 14 11-26-2015 02:06 AM
Failed rough inspection Usmoldmaker General Plumbing Help 12 08-09-2014 10:50 AM
Newest Threads
