Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > 5" toilet flange?
Thread Tools Display Modes
Old 11-12-2017, 07:28 PM   #1
bdrilling33
Default 5" toilet flange?
While working on my weekend project, i removed the old flange (glued in) and found that the pipe I was in measures 5" (i.d.) . The fitting is a 90. Can't seem to find anything this is 5", any suggestions on what i can do?
bdrilling33 is offline
Old 11-13-2017, 12:14 AM   #2
Mr_David
Easily Amused
Mr_David's Avatar
Liked 846 Times on 687 Posts
Likes Given: 562
Could be the inside of a hub that a 4" pipe glues into but that would be 4.5"
Here's a link to Fittings and pipe dimensions.
How about a picture Because that is very odd
http://www.charlottepipe.com/Documents/DimensionalCatalogs/Plastic_Pipe_Fittings_DC-DWV(609).pdf
a.k.a. Krazedav
Mr_David is offline
Old 11-13-2017, 12:34 AM   #3
bdrilling33
Ya know. I've measured this thing like 3 or 4 times. Racking my brain on it. But when someone asked you to post a picture of this on the internet, knowing full well they may find a way to make you look like an idiot, you make sure you triple check everything before and after the picture. It's 4.5"... down in the actual 90 is 4". So how do I combat this? I thought I bought a 3-4 one at first and it was way small.
Old 11-14-2017, 02:30 AM   #4
Mr_David
Easily Amused
Mr_David's Avatar
Likes Given: 562
4.5" is for accepting 4" pipe.
and a 4" closet flange glues onto that 4" pipe protruding from the closet bend fitting.
If your Closet bend is already flush with the floor you will need a4" spigot closet flange which should be the same diameter as the 4.5" pipe.
OR you do is glue in a short piece of pipe, but before you do that find a 3" flange. They O.D. is pretty close the I.D of the 4" pipe.
I like the Sioux Chief with the stainless steel rings
sioux-chief-flanges-884-ptmpk-64_300.jpg   toilet-flange-abs-knockout-stainless-steel-dims.jpg   shopping.jpg
a.k.a. Krazedav
Mr_David is offline
havasu Likes This
Flange issues on 3" drain pipe Ojloaf Toilets and Sinks 3 01-13-2017 08:08 PM
Toilet flange is 2" above baseboard norpus Toilets and Sinks 3 08-13-2014 02:58 AM
Type of toilet closet flange for 3" copper drain? maz General Plumbing Help 1 02-18-2014 06:40 PM
commercial sink "flange" question bradnerboy Project Display 6 09-12-2012 06:35 PM
Toilet 3/4" Above Flange Bobbyj General Plumbing Help 2 02-02-2012 12:25 AM
Newest Threads
