Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > just wont stay lit.
Thread Tools Display Modes
Old 10-17-2017, 11:00 AM   #1
Chrisjer
Default just wont stay lit.
I have a 40 gal kenmore propane water heater. I have a problem where the pilot light wont stay on. Reading up every one says it the thermopile and so i changed the whole burner unit. Still the same problem. So i changed the thermostat valve.. Still the same problem. Im at a loss to know what is causing it now. Any ideas?
Chrisjer is offline
Old 10-17-2017, 01:20 PM   #2
voletl
Liked 65 Times on 52 Posts
Is your chimney blocked?
Birds nest??
voletl is offline
Old 10-17-2017, 02:09 PM   #3
Chrisjer
I don't think so but will check again tonight
Chrisjer is offline
Old 10-17-2017, 07:56 PM   #4
Chrisjer
I checked from the top of the chimney all the way to the very top of the water heater. Just can’t figure it out. I think actually the the burner and pilot light is goin out before the water reaches temperature.
Chrisjer is offline
Faucet won't stay on (video) xfactor General Plumbing Help 7 02-23-2014 07:47 PM
FVIR Water Heater Pilot wont stay lit after cleaning filter arcsum68 Water Heaters and Softeners 33 11-29-2013 03:35 PM
Pilot light will not stay lit. jeff Water Heaters and Softeners 30 07-13-2013 04:15 AM
Hex nut on shower drain wil not stay tight tbakbradley Showers and Tubs 13 06-20-2013 02:40 PM
water heater pilot does not stay lit. Chris Water Heaters and Softeners 16 10-29-2012 04:46 AM
Newest Threads
