Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Fountain Water Supply
Thread Tools Display Modes
Old 08-16-2017, 04:15 PM   #1
garisilver
Default Fountain Water Supply
I built a custom fountain. The water splashes, so I installed a water supply for make-up water. I ran almost 50' of 1/2" ID reinforced tubing from the house supply and installed a float valve in the sump to maintain the water level.
It's been working great.
Recently, I bumped into the specs on the float valve. It says the max pressure is 10kg, which translates into 22psi.
The house pressure feeding it is about 65psi.
Even though it's working, I'm concerned about the pressure causing the float valve to fail. Does the 50' run of tubing drop the pressure at the valve? If not, can I install a pressure reducing valve, adjust it to 20lbs, and still have the float valve work properly 50' away?
Thanks in advance
garisilver is offline
Old 08-16-2017, 04:46 PM   #2
CT-18
Liked 29 Times on 25 Posts
No it will not drop the pressure.
CT-18 is offline
Old 08-16-2017, 06:02 PM   #3
garisilver
What about the second question?
can I install a pressure reducing valve, adjust it to 20lbs, and still have the float valve work properly 50' away?[/I]
Old 08-16-2017, 11:31 PM   #4
phishfood
Administrator
Liked 959 Times on 771 Posts
Likes Given: 1718
Sounds like a cross connection to me.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 08-17-2017, 02:31 AM   #5
Mr_David
Easily Amused
Mr_David's Avatar
Liked 822 Times on 664 Posts
Likes Given: 550
Float valve will still open and close if you drop the pressure with a reducing valve. 50 ft will not effect the flow that much. The volume you require will depend on how much water is lost through evaporation and leakage.
how may gallons of water will it require per recharge. 5 or 100.
some swimming pools was a small sump with a Fluidmaster toilet tank fill valve to maintain the water level. those will work at you current water pressure and they are inexpensive.
Or just get a better fill valve. reducing valve will cost maybe as much or more than just upgrading the fill valve
a.k.a. Krazedav
Mr_David is offline
Water fountain drains bluecamaro70 Drain and Sewer Cleaning 2 10-29-2016 01:35 AM
Main Water Shutoff--Won't Now Supply Water mikefixac General Plumbing Help 1 01-05-2016 02:39 PM
Turn off water heater when shutting off main water supply?? boostin Water Heaters and Softeners 16 01-16-2015 03:43 AM
T-ing Two Water Supply Lines for Greater Water Pressure JZeld General Plumbing Help 15 03-12-2012 08:13 AM
water supply th7385 General Plumbing Help 3 12-31-2011 03:33 PM
Newest Threads
