Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > New gas water heater
Thread Tools Display Modes
Old 08-15-2017, 01:59 AM   #1
Fiveoboy11
Default New gas water heater
Essentially like for like but 40 gallon new vs 30 old. New ball valve, water connections and temp/pressure valve rigged up to go outside. Anyone see any problems? I'm in AZ.
Fiveoboy11 is offline
Old 08-15-2017, 03:21 AM   #2
havasu
Administrator
havasu's Avatar
Liked 1086 Times on 880 Posts
Likes Given: 306
Some will say a drip leg is needed for your gas line.
havasu is offline
Old 08-15-2017, 05:19 AM   #3
Fiveoboy11
I checked and there is one back a bit, behind the shutoff valve
Thanks for letting me know about that
Old 08-15-2017, 12:21 PM   #4
Mr_David
Easily Amused
Mr_David's Avatar
Liked 822 Times on 664 Posts
Likes Given: 550
T&P relief drain can not go up hill.
You can not use soft/annealed copper or any type of flexible tube.
It has to drain downward. It can never ever be obstructed.
The end should terminate outside or to an approved receptacle. Where does the t&p terminate?
a.k.a. Krazedav
Mr_David is offline
Old 08-15-2017, 12:22 PM   #5
frodo
Just call me Macgyver
frodo's Avatar
Liked 1795 Times on 1531 Posts
Likes Given: 373
you need a pan and drain under the heater
your relief valve is piped incorrectly
the vent needs an offset
My advice is free, If I have helped you and you wish to help the site out with a gift
use this link
http://www.plumbingforums.com/forum/...faq=supporting
frodo is offline
Bosch Aquastar tankless water heater dripping, I have hard water ChicagoSuburban Water Heaters and Softeners 15 11-01-2016 08:04 AM
new hot water heater vs. old hot water heater / hot water longevity ?? Marco Water Heaters and Softeners 4 12-12-2015 09:31 PM
tankless heater in series with electric water heater olfclvr Water Heaters and Softeners 2 10-20-2015 06:29 AM
Gas tank water heater vs electric tankless water heater boblc123 Water Heaters and Softeners 4 09-21-2014 06:14 PM
Water heater feed pipe shot. and now i have to replace my whole heater. chucksrt Water Heaters and Softeners 1 05-20-2013 01:14 AM
Newest Threads
