I recently noticed the tank in 1 of my 3 bathrooms fills with hot water. Not warm water HOT water! I live in Montana a relatively dry climate. To the best of my knowledge there isn't an anti sweat valve, if there is it's buried in the wall. I read that a faulty shower cartridge could be the culprit. I wanted to try to prove this theory before buying a new cartridge. Not being a plumber I concluded by running the shower wide open with hot water while flushing and filling the tank multiple times would eventually produce cold water in the tank. It didn't. So my question is, is it possible that a faulty shower cartridge would allow hot water to flow all the way to the toilet? I believe the hot and cold lines run from the crawl space were the hotwater heater is located to the bathroom then t-off to the shower, sink, and toilet. It may be possible that my clothes washer is t-off of the same hot and cold lines. In the bathroom I turned the hot and cold lines off under the sink, while trying my "test" with the shower cartridge. Anyhow I ramble... if anyone has a suggestion or can provide quantifiable evidence that it's not my shower cartridge it would be appreciated. If anyone can offer a suggestion other the replace the flapper, anti sweat valve, or call a plumber that would be awesome!
