Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Is there a way to fix this dripping shutoff valve?
Thread Tools Display Modes
Old 04-26-2011, 09:17 PM   #1
ecrane99
Default Is there a way to fix this dripping shutoff valve?
I have pex pipe running to my outdoor wood furnace and noticed a puddle under this pump. Futher inpection revealed water dripping from the shaft that goes into the fixture where my finger is pointing. It drips in both the on and off postion. I tried to tighten the nut, but it just spins and wont get tight. Is there an easy fix, or do I need to replace? Thanks. Ed
ecrane99 is offline
Old 04-26-2011, 09:56 PM   #2
Mr_David
Easily Amused
Mr_David's Avatar
Liked 871 Times on 706 Posts
Likes Given: 577
A good ball valve will have a packing nut under the handle.
Yours uses the handle to press against a packing gland.
If you can remove the handle there should be a ring that may or may not easily come off. Try wrapping some teflon string or some tape around stem. reinstall brass ring. The handle, when tighten, should compress the teflon and my stop the leak. I would replace the valve
a.k.a. Krazedav
Mr_David is offline
Old 04-27-2011, 02:11 AM   #3
ecrane99
Thanks very much. I'll give it a shot. Otherwise will buy a new one.
ecrane99 is offline
Old 07-29-2011, 01:35 AM   #4
ecrane99
Default Update
I hired a plumber to replace the valves. It appears that the rust inhibitor I was using may have eroded the packing material to cause the valves to leak. I will need to dilute it. Thanks for the suggestions and help.
Ed
ecrane99 is offline
Old 07-29-2011, 03:53 AM   #5
Mr_David
Easily Amused
Mr_David's Avatar
Likes Given: 577
Awesome. Thanks for the feed back.
Glad you got it fixed.
a.k.a. Krazedav
Mr_David is offline
Old 07-29-2011, 05:02 AM   #6
AllAces777
AllAces777's Avatar
Liked 2 Times on 2 Posts
Man I love the follow up post like this!
Thanks!
If I had my life to live over again, Id be a plumber.
- Albert Einstein
╬-AllAces Plumbing of Las Vegas, Nevada-╬
AllAces777 is offline
Leak from toilet shutoff valve Kissimmee General Plumbing Help 3 04-01-2014 11:15 PM
Washer Machine Shutoff Valve ccg19072 General Plumbing Help 5 02-26-2012 12:00 AM
Quick Help! What tool to operate this shutoff valve? karma2000 Plumbing Tools and Equipment 2 02-14-2012 07:25 PM
Replacing outdoor shutoff valve geoffhazel General Plumbing Help 5 01-20-2011 08:12 PM
Shutoff Valve siezed abhi General Plumbing Help 3 11-09-2010 06:07 AM
Newest Threads
