Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > Materials for submersible pump install
Thread Tools Display Modes
Old 11-21-2017, 06:15 PM   #1
Cap
Likes Given: 5
Default Materials for submersible pump install
I have a few questions regarding materials.
Safety rope - Plastic or nylon? Any special type?
Electric splice - is there a goo to smear on inside the splice?
Check valve - is one enough (at pump) two hundred feet lift.
Pump controller - assuming the new pump rating & type is the same as the old one is a new controller required ?
Pipe - Schedule 80 - twenty five years old - 20' sections with couplings. Is there any reason why this cannot be re-used?
Cap is offline
Old 11-21-2017, 08:20 PM   #2
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 211 Times on 192 Posts
Likes Given: 46
Safety rope - Plastic or nylon? Any special type? Neither, do not use!
Electric splice - is there a goo to smear on inside the splice? Not needed. Either use barrel connectors and heat shrink kits or use barrel connectors and electrical tape if you know how.
Check valve - is one enough (at pump) two hundred feet lift. Yes, one only, the one on the pump.
Pump controller - assuming the new pump rating & type is the same as the old one is a new controller required ? Check the capacitors in the controller. If they are within 15% you can use the old ones. Some have one, some have two. Check if the overload protector is in the box or in the motor. You don't need two of them.
Pipe - Schedule 80 - twenty five years old - 20' sections with couplings. Is there any reason why this cannot be re-used? If the couplings are plastic, re use them. Galvanized, I would change the couplings.
speedbump is offline
Cap Likes This
Old 11-22-2017, 12:56 AM   #3
Cap
Likes Given: 5
Thanks speedbump ! I'm curious about the safety rope answer. My first pump (1968) had galvanized pipe and a plastic (IIRC) rope. This current pump (1993) has schedule 80 and no rope. Rope is no longer needed? More trouble than it's worth? Pollutant?
Cap is offline
Old 11-22-2017, 01:18 AM   #4
speedbump
speedbump's Avatar
Likes Given: 46
Rope is just something else to get stuck around the pipe on top of your pump keeping you from getting it out of the well the pipe is much stronger than the Rope.
Cap Likes This
Submersible utility pump not pumping with hose Code101 Pumps and Wells 1 10-23-2016 03:17 PM
Submersible Pump butch Pumps and Wells 2 09-21-2016 12:33 PM
Occasional (very) Low Pressure with submersible pump Beshmo_Handes Pumps and Wells 19 02-09-2016 01:35 PM
Submersible pump Mec Pumps and Wells 4 05-04-2012 02:53 PM
how to replace 110v lead to submersible pump?? kouvakis Septic Tanks 3 02-21-2012 02:41 PM
Newest Threads
