Kitchen drain line leaking in the crawl space.
redkendog
Aug 2, 2011
9
Indianapolis, Indiana
Hi! Any ideas where to start? Under the kitchen sink is dry. There is a little bit of 'gunk' matter present under the area that is dripping.
Thank you for any help you can offer me :)
If I'm correct that the wet spot is the subfloor then I'd start where the sink drain goes into the wall inside the cabinet. You may have a cracked fitting, a bad solvent weld joint, etc. That is, if you are absolutely certain that nothing is leaking or was spilled inside the cabinet.
i would guess it is leaking inside the wall, at the tee, where the trap arm conects to the stack'
it is not the 90 in the picture. you can see wet floor ABOVE the 90. so the wet floor is below what ever it is
looks like you get to open the wall up.
i recomend, cutting out the back of the cabinet, do your fix. then cut some plywood to patch the back wall of cabinet
no sheet rock mud or painting to do.
Update and fix to kitchen sink leak into the crawl space: As suggested, it was a T fitting that was leaking, and possibly never glued. Possibly knocked loose from the pressure of the dishwasher or the garbage disposal, or even snaking the drain line. The bummer was that I opened up the back of the cabinet before realizing that the leak was two feet over, behind the dishwasher. The hardest part of the job was removing old parts on the dishwasher to remove it.
As always, thanks for the input!
