Porkchopsnapplesauce
I'm a plumbing newbie, so please forgive me if I state something that is painfully obvious...this is all pretty new to me
I have been doing a lot of looking around and reading at LOTS of DIY drain clearing websites.
THE PROBLEM:
The sink in my bathroom will not drain.
HISTORY:
It started off as a slow drain. It would usually empty its self within 10 minutes. Then, being the newbie I am, I tried fixing it, grabbed the plunger, and went to town. Now, it won't drain at all.
THINGS I HAVE TRIED:
MISC INFO:
Is there any option im leaving out here? I really can't afford to call in a professional
THE PROBLEM:
HISTORY:
- Drain-O (failed)
- Something from Lowes thats "like" Drain-O but it's "corrosive" and claims to be "industrial strength" ... (failed)
- I climbed up on my roof and ran a hose full blast down both of my vent pipes for a long time each hoping it would do the trick. We had a brief glimmer of hope, because as I started to do it, the sink started to back up a little bit and fill with water...so I was hopeful it was clearing the drain. But after about 30 minutes each one running water...the sink still has not drained.
- Bought a manual pipe snake, 20 footer, and ran every last inch of it into the drain under the sink. Nothing.
- I took the trap under the sink off and made sure it was clear
MISC INFO:
- The toilet still flushes fine
- Bathtub drains perfectly
- Kitcken Sink & Dish washer both drain just fine
- I got down in my crawlspace to see if I could just take apart the plumbing under there, but its all PVC piping and it's all been glued together...no idea how the heck to work with that.
