norrisboat
I replace the valve stems for the hot and cold water a month ago. They worked perfectly until recently. The cold water works fine but the hot water stem seems to have a problem.
As the knob turns it doesnt come on at the point it used to. If I turn it a bit more it comes on and starts pulsating. You can feel the pipe in the wall vibrating. If I turn it on a bit more it comes on full with no pulsing.
What could cause this? Is the valve stem failing?
Thanks for the help
Thanks for the help
