Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Switching to gas WH, attaching vent pipe question?
Thread Tools Display Modes
Old 12-16-2017, 01:48 AM   #1
twinsig
Default Switching to gas WH, attaching vent pipe question?
Hello, first post here.
To the point. While my gas tech guy is gone hunting (no cell) I'm trying to complete the install in my house. I have the data & correct material to install everything!
Question is,,,, while my vent pipe is totally vertical through the ceiling & roof,,,,, how is it I move the WH into place if the vent pipe is installed (can't move it up or down)?
Top of vent cap is 61.5" AFF (from spec sheet) and I'm guessing my vent pipe needs to be the same?
How does this work, I slide the WH in place and momentarily squash the vent cap?
Thanks, and if you have electrical questions I can probably help you on that.
twinsig is offline
Old 12-16-2017, 04:58 AM   #2
Mr_David
Easily Amused
Mr_David's Avatar
Liked 871 Times on 706 Posts
Likes Given: 577
??????????. Vent cap goes on top of the vent.
You might be referring to the draft hood.
Pictures.
who installed the vent? permanent part of vent going through roof should have adequate space above the heater to connect it with additional connectors after the heater is in place.
Maybe you should wait for your guy to bag his dinner.
a.k.a. Krazedav
Mr_David is offline
Switching from Kohler to Delta or other faucets dumplump General Plumbing Help 4 03-01-2017 04:20 AM
Vent Pipe question - Massachusetts MTadry Plumbing Building Code 4 12-24-2014 02:22 AM
ABS vent joined to inside of other ABS vent pipe edee_em General Plumbing Help 0 11-20-2014 05:28 PM
Vent pipe question... 1234 Plumbing Building Code 4 06-06-2013 04:49 AM
Switching From Natural Gas To Electric Water Heater...What To Do With Gas Pipe/Valve? Abraham General Plumbing Help 3 05-14-2010 02:31 PM
Newest Threads
