vineyridge
I have a 1200 foot deep well with a 3hp motor. It feeds into a 1000 gallon steel pressure tank. The system was installed about 30 years ago, and the pressure tank is beginning to rust out to the extent that it needs replacing.
1000 gallon pressure tanks are very expensive.
The reason this one is so large is that it services 4 houses, a wash house, and a farm filling station for filling 500 gallon tanks for chemical mixes. One of the houses is about 1/4 mile away but everything else is within 500 feet of the well.
I've been wondering if it would be cheaper to buy a water storage tank and a smaller bladder pressure tank and use the two together to get the water pressure and amounts that I need. But no one here has any expertise with a system that would work that way. I do know that the bladder tank would be too small when the farmer is filling his tanks. How one would hook up a system with a storage tank and a pressure tank is beyond me.
So can any of you experts give me some advice? The only person that I've talked to here says replace the steel pressure tank with another comparable size pressure tank.
