Thank you in advance for your time and response. Today I noticed that the toilet would not fill. I knew a lot of water was being wasted so I used the valve beside the toilet to shut off the water to the toilet. I saw that the seal ring was worn. I purchased a new one and attached it to the canister.
I turned the water back on and the toilet filled and flushed properly. However, after a few flushes I heard a hammering/motor sound. So I turned the water to the toilet back off which stopped the noise. Then I turned the water back on just a little. The toilet fills normally but slowly since I only turned the water on a little. I have flushed the toilet several times and the toilet seems to be working well. I have not heard the noise again and I have not turned the water all the way back on.
Will leaving the water only turned on a little cause problems in the future?
Did I mess something up by turning the water off?
