Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Tools and Equipment > Trying to repair a Toledo Port-A-Pony 68 pipe threader
Thread Tools Display Modes
Old 06-20-2017, 02:46 AM   #1
okrobie
okrobie's Avatar
Liked 3 Times on 2 Posts
Default Trying to repair a Toledo Port-A-Pony 68 pipe threader
I know, it's too old. Why do you want to fix that old dog? Well, just because.
The motor is stalled. It tries to run, but the gear box is hung up. I'm trying to remove the end bell with the gears, but I can't get the gear off of the motor shaft. It has a key, but I don't see a set screw or any pin. Just the key. I got a bearing puller and tried to get it off that way, but no luck. Has anyone got experience with this issue? Thanks for any help. Jim
okrobie is offline
Old 06-20-2017, 10:40 AM   #2
okrobie
okrobie's Avatar
When I close the switch to the motor, it starts to hum and the lights dim. It is plugged into a receptacle box, and onetime the "klixon" overload tripped.
okrobie is offline
Old 06-20-2017, 02:03 PM   #3
havasu
Administrator
havasu's Avatar
Liked 1114 Times on 906 Posts
Likes Given: 336
Sorry, I have no idea.
havasu is offline
Old 06-20-2017, 03:16 PM   #4
Mr_David
Easily Amused
Mr_David's Avatar
Liked 869 Times on 706 Posts
Likes Given: 577
I like That! "Just because"
I sometimes take pleasure in breaking things down to see if I can fix them.
Sometimes the parts you need to fix them are no longer available or you inadvertently destroy a major component.
Good Luck with that.
a.k.a. Krazedav
Mr_David is offline
Old 06-21-2017, 10:11 AM   #5
okrobie
okrobie's Avatar
I found a nice design for a home made bearing puller. I think I'll give it a try.
okrobie is offline
Old 06-21-2017, 10:24 PM   #6
okrobie
okrobie's Avatar
Well I wen't to NAPA auto parts and got a real bearing puller and that did the job. Now trying to get the armature out. Think there might be a bad bearing on the other end. Also dealing with a bad brush holder. I'll keep you informed as more is revealed.
okrobie is offline
People Like This
Old 06-26-2017, 11:26 PM   #7
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
I like old tools, love to bring them back to life and use them for their intended purpose.
I have an old Nye pipe vise of my Dad's that gets used every time I have a gas pipe job to do. And it grabs pretty good.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 07-02-2017, 02:54 AM   #8
okrobie
okrobie's Avatar
Hi phishfood, I like your attitude!!!
I still don't have that armature out of the motor. I didn't want to force it. I think I'll post some pix to see if anyone can come up with an idea.
BTW the other end bell dos'nt open.
okrobie is offline
Old 07-02-2017, 03:56 AM   #9
okrobie
okrobie's Avatar
I just realized that I never posted an image of the real thing. This is a copy not mine.
okrobie is offline
phishfood Likes This
Pipe threader MobGod Plumbing Tools and Equipment 4 02-08-2016 10:31 PM
Waste Pipe Repair goknights General Plumbing Help 8 11-15-2015 11:08 PM
Exposed vs enclosed pipe threader robby82 General Discussion 3 02-15-2015 05:40 PM
Pitbull hand threader TylerF1986 General Plumbing Help 0 11-08-2013 05:19 PM
First Time Using a Pipe threader Bioman General Plumbing Help 4 04-30-2011 03:10 PM
Newest Threads
