Mystery drain hose into bathroom sink drain
Something to check
Where is your water heater in this condo? Could this be a T&P relief drain
Typically a condensate drain is 3/4 inch
A lot of old relief lines were 1/2
Something to check
After double checking it, the relief is hooked up through hard copper and feeds back into a shared wall with a neighbor. where is goes from there is a bit hard to tell. Though I will also mention, the pipe coming out of the wall at the sink is PVC, It doesn't seem very likely, to me, that somewhere in the walls there is a transition from copper to PVC.
