Hey all. What I got going on is a RO/DI unit for a salt water fish thank. The unit gives out waste and clean water. The waste water is still good and can be used to water plants, drinking, or whatever. I have the waste water line going into a trash can in my garage. I also have a slop sink (utility or laundry sink whatever you call it)
What I want to do, is have a pump in the trash can and run either a PVC piping, or a hose of some sort to the sink. I want the pump to run the sink. I guess my question is what type of pump and what does it need to pump to have enough water pressure for the sink, but not anything too powerful to burn out the pump. Right now I have a sub pump, which does 1300 GPH. But I use that to transfer the salt water to my tank. I dont think I need something as powerful as that. What size pump should I use.. Obviously I will just plug it in as I need it, unless I can find something that only turns on after a water flow.
I was thinking about making the trash can elevated and using gravity to feed the sink, but I dont want to risk any damage to the trash can and Not sure if it will be high enough to run the sink. (its only in the garage)
Also, the trash can will have a small hole a few inches from the top with a PVC pipe ran from the trash can to the sink drain as an over flow just in case it makes water when I'm not home.
Thank you for your help in advance.
