Why expansion tank needed ?
raypunzel
Jan 6, 2010
Upon buying our home a few years ago, the hot water tank started leaking through the overflow tube. We were told that the tank needed replacing. The home warranty covered the cost of the tank. My question is why an expansion tank was needed along with the replacement water heater when there wasn't one plumbed in before?
BTW, it is a gas heater.
Ray
I'm not a bonafide plumber, but it sounds like your temperature / pressure relief valve is faulty. I've had a few go bad and are easily fixed. Just make sure you shut down the system, drain the water, replace the valve, and fill it back up.
