Washing Machine Valve Leaking
mtcellar
Nov 16, 2015
When I open the washing machine valves back up, after closing, there was water leakage through the stem o-ring, I’m guessing it got old and cracked. I was going to switch out the valves themselves, but when I put a vise grip on the t fitting and a monkey wrench on the valves, they would not budge under significant torque. I do not want to crack the solder joints or any fittings, as the problem would multiply from there.
Please see the attached pictures. The t-fitting is Nibco but I do not recognize the symbol on the valves themselves. Can someone help with who made them? In the end I am looking for an o-ring and nut kit to seal both valves back up. The o-ring ID is 10 mm, and the nut is 20 mm across the flats. I would guess they’re standard sizes as I live in the US and they look to be 40+ yrs old, but the metric dimensions supplied were pretty dead on.
Thanks all!
John,
Thanks for the reply. As I said in my original post, I put a vise grip on the tee and a monkey wrench on the valve. it feels like if I torque any harder I'm going to pull something in me of break something on the line!
Are there any tricks to get the fitting to loosen up? Like I said, I don't want to bust either of the pipes or tee fitting.
