R rick Member Joined Jan 6, 2010 Messages 5 Reaction score 0 Location , Jan 6, 2010 #1 I need to remove shower door frame from cultured marble walls, the frame is silliconed onto the marble. Any tricks to use that won't break the marbl?
havasu Administrator Staff member Admin Joined Jan 5, 2010 Messages 12,413 Reaction score 3,498 Location Southern California, Jan 6, 2010 #2 I would use a new, sharp razor blade, with some soap as a lubricant to avoid scratching the surface. Finish with a Goo Be Gone or similar product, but test before using to prevent staining.
R rick Member Joined Jan 6, 2010 Messages 5 Reaction score 0 Location , Jan 6, 2010 #3 been using razor with no luck, however your idea of a soap lubricant sounds good.
