Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > What is this pvc part?
Thread Tools Display Modes
Old 01-27-2018, 01:17 PM   #11
Mr_David
Easily Amused
Mr_David's Avatar
Liked 895 Times on 726 Posts
Likes Given: 593
One big dif is that plastic fittings are cast in a mold and metal ones are cut with a die.
typically Plastic male fittings are screwed into metal female fittings.
Pipe threads are tapered, and male fitting are like a wedge.
The tighter you make the joint, the more outward pressure you exert on the female fitting.
A plastic female fitting on a metal male is likely to fail 1st?
The plastic male fitting will compress in the metal female
Plastic male fitting also can and do fail.
Their weakness is the valley of each thread.
They always crack at the thread outside the joint.
We try to always use Schedule 80 fittings.
If you have to use a plastic female you can increase longevity by putting a hose clamp around the fitting
a.k.a. Krazedav
Mr_David is offline
journeyman Likes This
Part ID help? Snapcrackler General Plumbing Help 1 10-25-2016 02:32 PM
What Is This Part cchace Showers and Tubs 0 09-15-2015 05:43 PM
What is this part? Pete_K Plumbing Products 2 05-27-2015 01:48 PM
Is this the replacement part I need? (PRV) Ohmama General Plumbing Help 0 01-30-2015 07:07 PM
What is this part? amazin6 General Plumbing Help 11 05-05-2012 03:19 PM
Newest Threads
