caulking bathtub
dolfans
Active Member
Jun 10, 2011
32
Mt Airy, NC
How often do you guys caulk your bathtub? Do you use caulk or that tape? I cant caulk it and let it harden for 3 days,last time about 1.5 days,said it is ok. I was thinking can i put that tape caulk stuff over the caulk? If so can i put it on with the older caulk? I hate caulking. Thanks
That tape is junk. Your best bet is to fill the bathtub half way with water. This places much needed weight into the tub providing a nice caulk seal. I know you hate this part, but get a razor blade and cut all the old caulk out of the joint, and clean with rubbing alcohol so you will have a nice bite with the new caulk. Next, use the blue painter's tape and run two parallel lines as close as possible to the seam with one tape line on the tub and the other on the wall. Get a good quality caulking with silicone which matches the tub. Apply a liberal bead directly between the joint. Spit on your finger, which allows for a smooth joint, and make the bead feather to nothing on the taped edge. Once you get the desired look, pull your tape and leave it that way for at least 24 hours, making sure not to disturb the water in the tub or allowing water to get on the new caulking. After 24 hours, the caulk will be set and you can drain the tub and use it for years without having to redo this arduous task.
Good luck!
I would not recommend using the tape, it peels and does not last like regular caulk. Before caulking make sure you totally remove any old peeling caulk residue, otherwise your efforts will go to waste within weeks. Using the tape over the caulk would do no good and probably even lessen the effectiveness of the original caulking.
