Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Unusual project. How strong are sweated copper joints?
Thread Tools Display Modes
Old 04-07-2012, 01:43 AM   #1
Joelk
Default Unusual project. How strong are sweated copper joints?
I am doing a unique (as far as I know) project and am pretty sure it will work, but not sure how well.
I have a LOT of air tools. I have not counted, but well over 50 of them. I am going to construct "racks" out of copper pipe and tees to hold them.
I am using air tool couplers that are much larger than typical couplers. They fit almost(but not quite) snug in the "ports" of a 1/2" copper tee.
I have purchased 100 tees and am cutting type L copper pipe to connect them together leaving 1/4" between the tees. The branches that will hold the tools will come out at about a 30?? degree angle and at the ends of each "run" I will put a tee vertically to keep the other tees in the correct position. My plan is to drill a hole through the end tees to hold the racks onto the wall/rafters. If need be, I will drill holes through the pipe in between the ends to keep it from bending the copper and/or breaking the solder joints.
If I can, I will probably run 20 or more tees on each "rack" as I would like to put them near my work areas.
My question is, how many of these can I run in a row before the pipe and/or joints will bend or break?
I realize this will largely be dependent upon how long and/or heavy the tool is(and also the angle). Some will be lightweight, like tire chucks/inflators, some medium weight, like small die grinders, and some fairly heavy, like air ratchets and impact wrenches.
Will a rack support 10 average 1/2" impact guns with just a screw through a tee on each end? If I need screws "in the middle" how far apart should I space them?
How strong are soldered joints? Will the joint bend/break before the pipe/tee will bend/break?
How strong is 1/2", type L pipe? How much twisting force will it withstand before it will bend/brake?
Any suggestions on how to keep the tees in "perfect" alignment while I solder them?
What angle would you suggest that I hold the tools at?
Thanks, Joel
Joelk is offline
Old 04-07-2012, 09:12 PM   #2
mccmech
As copper is a soft metal, in addition to being on the expensive side, I would not recommend it for any racking/shelving system. If, for some reason, you want to use copper because ya have a bunch of it laying around, I would suggest scrapping the copper & using the proceeds to buy either 3/8 or 1/2 black iron pipe & fittings to do your shelving. Just my .02 worth. You do what ya want or what someone else may suggest. Best of luck with your project though.
mccmech is offline
Old 04-07-2012, 09:35 PM   #3
Joelk
Thanks for the reply, but I'm not sure you understand the design I am planning.
I plan to insert the air tool coupler into a port of the tees to hold the air tools. If I used iron it would quickly cause wear damage to the couplers. I WANT a soft metal so that it will not cause a significant amount of wear on the couplers.
I will have less than $50 in materials, so if it works well, I am not concerned about the expense.
Joelk is offline
Old 04-08-2012, 12:15 AM   #4
Fansplumbing
Master Plumber
It'll work but I'm not sure how much weight they'll hold. Have you thought about going up to 3/4" or 1" copper?
Fansplumbing is offline
Old 04-08-2012, 03:27 AM   #5
Joelk
Using 3/4" or 1" would no doubt be stronger, but would significantly increase the cost.
I got 1/2" tees for under $0.60 each. I have not shopped for the best price on 3/4" x 3/4" x 1/2" tees, but I would guess they would cost 3 to 4 times as much.
I think I will build a "ten post rack" using 1/2" tees/pipe and see if it will support the tools. If it holds up, I'll make more like it. If not, I'll cut back on the # of posts per rack.
Joelk is offline
Old 04-11-2012, 02:28 AM   #6
Joelk
I have proceeded with the project and it seems to have worked out very well.
The first rack I made had 40 "ports". I put an "attachment tee" at each end and one between each 10 ports. I ran a 4" piece of pipe up from each attachment tee and put a screw through each attachment tee and one through each piece of pipe that runs up from the attachment tees. I have it fully loaded with tools and have "tugged on it a little bit" and it seems like it will hold the weight just fine.
After constructing the first rack, I made a couple more. On these I just put a screw through the attachment tee at each end. It seems like one screw at each end is adequate and at this point I do not plan to put on the pieces of pipe at the attachment tees. One of these racks has 10 ports, and the other 15. I only plan to put lightweight tools like tire chucks, blow guns, etc. on the one with 15 ports.
Joelk is offline
Old 04-16-2012, 01:32 PM   #7
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 211 Times on 192 Posts
Likes Given: 46
I can tell you that copper is very tough and the soldered joints are real tough. I once repaired a fitting on my Dad's Backhow that got knocked off. I got the broken thread out of the boom, screwed in a 3/4" male adaptor, a short nipple and a Street Ell soldered in place finished the job. It was supposed to be temporary as I didn't think the copper joints could take the 2000 psi + that a hydraulic pump puts out. It did, and was on there for several years and lots of use.
speedbump is offline
An unusual problem regarding cooling hot water in pipe clgan General Plumbing Help 4 04-20-2012 01:15 AM
Preventing leaks copper joints AJay General Plumbing Help 16 09-09-2011 02:06 PM
Un-done joints dwc General Plumbing Help 8 06-25-2011 12:10 PM
Unusual Tub Drain stevevh Showers and Tubs 20 02-20-2011 03:32 PM
Unusual Drain Problem. What to do??? thingyado General Plumbing Help 1 04-29-2010 12:01 AM
Newest Threads
