P trap variations
Kado
Jan 24, 2011
Cincinnati, ohio
This has probably been discussed somewhere, but I could not find it... so here it goes (I apologize in advance for the elementary nature of the attached images):
I have three new vanities and one new tub to install but have space constraints for the traps that need to go in. The drain from the wall is just above the bottom shelf of the vanity - effectively making it impossible to place a standard trap without cutting the vanity. So the question is this, can a p-trap be installed above the wall drain and have two 90 degree (or 45 degree) elbows route the water down into it from the trap? See the attached image figure A for a better visual
Also, with respect to "p-traps", typically the drain goes straight down into the U part of the trap. Then the flow goes back up until it hits the 90 that sends the flow horizontal. Does it matter what angle that horizontal extension comes off the U portion of the trap? Can it go back over like a loop or is this a big "no-no" for some reason? I would love some explanation on this subject because one guy told me that it makes a difference whether the final bend in a P trap goes straight back vs left/right/over... I don't understand the physics of why that would make any difference, but maybe someone can shed some light on it for me. See figure B and C for a visual. I would like to use the "loop" option (figure C) for the tub trap. Does anyone see an issue with this?
If anyone can refer me to some technical literature, that would be helpful too.
Thanks in advance
Figure A and B are against code, as the height difference between the outlet of the trap and the attachment to the vent is too great. This creates a situation known as an S-trap, and can cause the trap to siphon itself empty when the fixture drains.
There is no issue with Figure C that I am aware of, other than that it looks kind of funky. I have had to do the same thing many times, and have encountered no problems with it.
Ok, Figure A & B are no good. I understand how they "could" syphon dry from a physics stand point, but there would need to be a lot of negative pressure for that to happen and the actual stack/soil vent is less than 2 feet away from those fixtures.
I've set both of those configurations up already because I did not want to destroy the furniture, nor did I want to open up the wall (which by the way would have required the exact same pipe bends but in the wall rather than out of the wall). Both have been extensively tested and no syphoning issues have been observed. However, for what it's worth, I would like to have everything up to code... so if there is a proper solution to match drain heights, I would love to know about it...any suggestions?
Open the wall and move the santee to where you want it.
You can raise it and move it left or right by turning the trap arm parallel to and in the wall with a 90 fitting coming out of wall where you want it.
You can change the direction of the trap arm with not more thanone 90 degree or two 45 degree fittings.
No dice on moving the "santee." The santee in the wall moves horizontal a few feet until it merges into the main stack/vent. So modifying that vertically would effectively create the same flow issue that I've created outside the wall. I mean, I don't know what the code says about that stuff... but to me that sounds like a "make work" project as I would still be faced with the same number of bends and changes in elevation in the piping after the modification.
Now you're saying the p trap arm direction can be changed with two 45 degree bends? So, in Figure A from the original post, if the GREEN and PURPLE sections of pipe were 45 degree bends then it would be okay? If that's true, then that method will get me to my objective. I've used 90 degree bends for now because that's what I have... but I can go pick up a few 45s to get it sorted out if that will put it into compliance.
Thanks in advance
You simply need to install an auto-vent, after the p trap at the highest point of your down down turn. It would be impossible for the s portion of the trap to auto siphon. If auto vents are allowed in your area.
How can figure C work if you said the bottom of the trap hits the shelf?
Myself, I would just take a jog saw and cut a nice square to accommodate the trap. The dummies who design this junk have obviously never plumbed anything before.
Check the dates of the post just before OnSiteRenovations revived it.
Hope the OP resolved it by now. :cool:
