Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Tub spout - can't get old plastic sleeve off
Old 12-15-2013, 02:16 PM   #1
BillCz
Default Tub spout - can't get old plastic sleeve off
This seems like a dumb question, but I don't know the answer, so...
The diverter on my old tub spout isn't working well anymore, so I want to replace the tub spout. I have a 1/2" copper pipe slip connection. I took the old main unit off and what was left behind was the plastic sleeve shown in the picture. This sleeve is quite loose - I can twist it around the pipe freely and can pull it back and forth on the pipe a very tiny amount. But I can't pull it off. I've pulled up until the entire copper stub out is pulling out of the wall. I don't want to pull any harder and break a solder joint in the wall or something. It sort of looks like the shiny copper with the groove in it that you can see through the slot in the plastic may be holding things up - it almost looks like an extra sleeve over the pipe. Although if it is, it is very thin. I've thought about trying to cut off the plastic sleeve, but I'm worried about burning my bridges - at this point I can still go back to the old spout.
Does anyone know what is going on here, and can provide me with advice?
Thanks in advance,
Bill
BillCz is offline
Old 12-15-2013, 02:25 PM   #2
Liked 391 Times on 328 Posts
Likes Given: 556
There should be an allen (inset hex) head screw, on the bottom of the collar. Turn the slot in the plastic collar down to the bottom, and see if you can't remove it.
Zanne Likes This
Old 12-17-2013, 12:09 AM   #3
BillCz
Thanks for replying. However, that isn't it. The white collar is just a smoothly molded piece, no screws or holes for screws or anything.
Any other ideas?
Thanks.
BillCz is offline
Old 01-31-2014, 12:51 AM   #4
MelCon1116
Default How to remove plastic sleeve
I'm sure you have solved your problem; however, maybe this will help others as I had the same problem. There is a black o-ring which seats itself very tight in the plastic sleeve. After about 15 minutes (possibly more) I thought this plastic piece was not going to get the best of me. I pried the gasket out with a pair of tweezers and once that was removed the sleeve came off with ease. This was my first attempt at a repair and it was quite easy and would have taken less time if this little part didn't give me an issue. Hope this helps.
MelCon1116 is offline
Zanne Likes This
what is this recessed plastic shelf in my apartment bathroom? d3k General Plumbing Help 3 12-05-2013 11:33 PM
Push fitting question? Sleeve below the teeth. adabiri2 Plumbing Products 1 10-23-2013 11:23 AM
New Plastic pipe melmar General Plumbing Help 4 04-22-2013 08:23 PM
Cutting Plastic Pipe blitz Plumbing Tools and Equipment 21 06-01-2012 03:27 PM
Plumbers Putty on plastic index1489 General Plumbing Help 1 03-22-2012 01:26 PM
