Check to make sure the drain is opening all the way. Mine was doing that recently and it was the little chain that operates the drain plug deal inside the pipe. If it is a standard shower/tub, remove the two screws that hold the faceplate on the lever for the drain and pull it out. If it drains fine then, you've found the trouble. If not, you are a little closer to finding it!
