Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Showers and Tubs > Smell in shower drain
Old 05-18-2012, 04:04 PM   #1
Default Smell in shower drain
I had all of my shower plumbing redone three years ago and now I have a smell in my drain that only seems to appear after showering. I have cleaned the drain (using various methods and products) and today even had a plumber run a "smoke test" to check for an air leak in the lines - nothing. I am stumped. The plumber also suggested it might be my hot water tank but no other places smell when the hot water runs/collects.
If anyone has any thoughts I would love to hear them. Thanks so very much.
Ar5475 is offline
Old 05-18-2012, 11:00 PM   #2
Liked 108 Times on 93 Posts
Likes Given: 239
Nothing comes to mind, but I am staying tuned to see if someone else can come up with a credible explanation.
Old 05-19-2012, 01:08 AM   #3
What kind of smell?? Rotten eggs( sulfur)????
bnut1973 is offline
Old 05-19-2012, 01:11 AM   #4
Uassually showers u notice a smell first because the trap is so close. It also could be a buildup of veal in your overflow.
bnut1973 is offline
Old 05-19-2012, 01:29 AM   #5
Liked 2 Times on 2 Posts
You said you had all your plumbing redone.
That does'nt mean it was done right.
What exactly was redone?
Was this a tub/shower or just a shower.
tile/fiberglass/ ?
You say you smell odors after you use the shower.
I could be possible it wasn't vented properly and the p-trap ( providing there is one) is not holding the trap seal.
Stand alone showers require a 2" drain and you should be able to look down into it and see water holding in bottom of drain.
Mr_David is offline
Old 05-31-2012, 02:33 AM   #6
Banned
My friend had the same issue. But I failed to ask what exactly she did to fix it.
littlesamara is offline
Old 05-31-2012, 03:51 AM   #7
was this smell noticablle immediatelly after the work was done or is it recent.
could be as simple as hair and such caught up in the p-trap. I have once found a problem like this caused by a hangar underneith ( galvanized strapping ) not done well at all ( a nail placed through the loop and not a stove bolt ) that released and caused the line to bow and in effect created an s trap that partially syphoned the trap after use. problem was resolved by properly supporting the pipe and checking grade. though this was a very odd instance and unlikely in many cases, my intent is to say that there are a number of things, some subtle that can cause issues.
LiQuId is offline
Sewer smell in shower stall briancfranks Showers and Tubs 4 08-08-2012 07:29 PM
Sewer smell after shower/bath (occasionally) Toribean Drain and Sewer Cleaning 6 01-10-2012 07:05 AM
Floor drain to shower drain conversion gooch43 General Plumbing Help 1 11-21-2011 11:51 PM
Sewage smell after shower caspurr6 General Plumbing Help 17 12-08-2010 04:13 PM
What to use to get rid of bad smell in drain yjislander Toilets and Sinks 3 02-26-2010 01:55 PM
