Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Simple question on shower head connection
Old 02-01-2014, 09:38 PM   #1
snrusnak
Liked 34 Times on 29 Posts
Likes Given: 2
Default Simple question on shower head connection
I'm threading the shower head "arm"(whatever it's called) in to the wall and when it snugs up it's 180 deg upside down. I can't force it another 180 deg(it's bottomed out). I'm using liquid pipe sealant(rectorseal 5).
Should I just go all the way as far as I can to where it's in the proper location and let it harden? It's pretty loose. My fear is my wife will by rough on it(we are using one of those detachable shower heads) and it will break the sealant and start leaking in the wall and I won't realize it.
snrusnak is offline
Old 02-01-2014, 09:39 PM   #2
snrusnak
Likes Given: 2
Should have also mentioned it's metal to metal connection.
snrusnak is offline
Old 02-01-2014, 10:56 PM   #3
thedrainguy
Wrap the shower arm threads with teflon tape, and coat tape with rector seal, now thread it in.
The tape should make the fit a bit more snug so you can stop it at the correct position.
Matt
thedrainguy is offline
Old 02-02-2014, 06:28 PM   #4
Liked 391 Times on 328 Posts
Likes Given: 556
I usually use 6 or so wraps of teflon tape, then dope on top of that, as the previous poster said. One handle of a pair of pliers inside the arm to tighten it down.
Make sure to flush through the shower arm thoroughly before you install the head.
2
People Like This
Old 02-03-2014, 12:15 PM   #5
snrusnak
Likes Given: 2
I'll give it a shot, thanks.
snrusnak is offline
Old 02-06-2014, 03:00 PM   #6
snrusnak
Likes Given: 2
still seems very loose. Should I wrap it even more with tape?
Any other options?
snrusnak is offline
Old 02-07-2014, 01:24 AM   #7
Likes Given: 556
How many wraps did you use?
That is a bad spot to have a leak, as you mentioned, you don't usually know about it until a lot of damage has occurred. If you can't get it to tighten up, I would get another shower arm and try that. Thread sizes can be slightly different.
Old 02-07-2014, 01:27 AM   #8
Liked 419 Times on 350 Posts
Likes Given: 62
Just confirming you are threading the correct end?
Old 02-07-2014, 02:57 PM   #9
snrusnak
Likes Given: 2
I wrapped it around 4-6 full wraps.
Long end into the wall. Is that correct?
snrusnak is offline
Old 02-07-2014, 03:06 PM   #10
Likes Given: 62
Usually, but not always. Are there differences in the ends?
My biggest concern is with 6 wraps of teflon tape, and it is not tightening, I'm concerned that the opposite elbow may have been split. Can you confirm this?
Home Pressure Regulator connection question dsteele11 Plumbing Building Code 1 01-15-2014 02:12 PM
Simple Wax Seal Question hlxdrummer Toilets and Sinks 0 06-13-2013 12:28 AM
Simple Plumbing Question DumbPlumber General Plumbing Help 1 11-11-2012 01:34 PM
Dual head shower Remodeler Showers and Tubs 15 08-22-2012 03:54 AM
Question about shower head valve replacement. LeftIsHot Showers and Tubs 2 03-23-2010 01:24 AM
