Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > shower valve embarassment
Old 06-08-2013, 11:07 PM   #1
eocarp
Default shower valve embarassment
Help!
New here and to this forum, I currently have a head scratching problem, I cant solve. Used to work in plumbing years ago, now im rusty and outdated.
had a delta monitor1400, went to change the cartridge, and cracked the valve. Okay off to lowes, bought a delta multichoice valve, and a new cartridge, only cartridge they carry fits delta and 1400.
Changed new valve, installed new cartridge, ahhh, now to adjust heat. bring house water back on, showers running and wont shut off???, lets check, yes cartridge installed correctly hot indicator on the left, valve installed correctly, up arrows are pointing up. huh?
im stumped, why wont shower shut off?
Thanx E
eocarp is offline
Old 06-09-2013, 12:30 AM   #2
There are two cartridges for the Delta 1400. The old style which is longer than the new.
johnjh2o is online now
Old 06-09-2013, 01:52 AM   #3
eocarp
Thank you John,
The cartridge i have is the delta RP19804, says it fits 1300& 1400 valve bodies.
Although there is no mention of if fits the new multichoice valve which is now installed.
It is the only one available at lowes however.
E
eocarp is offline
Old 06-09-2013, 02:40 AM   #4
Here is a link showing both cartridges.
https://www.google.com/search?q=delta+1400+series&rlz=1CASMAE_enUS525US52 6&oq=delta+1400&aqs=chrome.0.59j57j0l2.10782j0&sou rceid=chrome&ie=UTF-8#q=delta+1400+series&rlz=1CASMAE_enUS525US526&sou rce=univ&tbm=shop&tbo=u&sa=X&ei=UuqzUduTGe6q0AHAq4 HYBw&ved=0CDsQsxg&bav=on.2,or.r_cp.r_qf.&bvm=bv.47 534661,d.dmQ&fp=d1b72d04d0521783&biw=1366&bih=656
Old 06-09-2013, 11:56 AM   #5
Liked 178 Times on 146 Posts
Likes Given: 130
The multichoice valve takes the RP46074 cartridge if it's set-up as a standard single lever valve. The RP1908 is for the mointor series valves. The cartridges are not interchangeable. The 46074 cartridge is longer than the 1908 cartridge as John stated.
IFIXH20 is online now
Old 06-15-2013, 03:03 PM   #6
camaroderrick73
camaroderrick73's Avatar
Liked 30 Times on 29 Posts
The way I do it, is grey delta cart vs blue cart ( meaning the back of the cart is this color) they are slightly different and not interchangeable. Make sure y match grey with grey and blue with blue...
Hope that helps
camaroderrick73 is offline
Old 06-15-2013, 10:34 PM   #7
stevemachine
Liked 89 Times on 78 Posts
Likes Given: 91
Hope that helps
I agree for the most part, I've pulled out the "blue" ones and they weren't blue, so what I found is get the old cartridge and butt the hot and cold inlet together with the new cartridge. The two different cartridges have a different Centre to Centre measurement
shower valve ID? DetroitRob Showers and Tubs 14 03-12-2013 11:12 AM
Shower Valve ID eliteplumbing Showers and Tubs 2 01-09-2013 04:41 PM
Shower Valve ID mmcpeek Showers and Tubs 1 10-20-2012 11:45 PM
Shower Valve ID partizan92 Showers and Tubs 5 02-27-2012 12:16 PM
Need help with shower valve OD354 Showers and Tubs 22 05-28-2011 08:13 PM
